Old 08-28-2004, 06:12 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Bob makes a very good point. The vac. hose should be connected to the base of the carb and the PCV valve. On the opposite valve cover there should be either a connection to the air cleaner or a breather.
The vac. hose removes every gas, mist and/or fart that forms inside the crank case and allows it to be burned. The breather/air filter connection makes sure the air being drawn from the crank case is not dirty, filthy sand impregnated junk. ( a little graphic, but this needed a bit of drama, LOL )
Just my $0.02
