Old 08-30-2004, 01:21 PM
chuckcobra chuckcobra is offline
Cobra Make, Engine: CSX3193, replica 289 Cobra and replica Daytona Coupe Cobra
Default Daytona coupe interior sound and heat insulation
In about 900 miles of Daytona coupe street test driving, one of the main "issues" that needs to be addressed is the reduction of interior noise level.
This past weekend, I borrowed a sound meter to measure interior noise levels. Keep in mind that the interior of the coupe is completly bare aluminum, so I was prepared for some high noise readings. I only got to do one test and the meter hit 99.5 dB(A) while crusing at about 45 mph. I didn't capture a measurement for a full throttle run, but it was significantly higher.
Whatever sound attenuation material that I use must be applied in a manner that does not detract from the original interior look (e.g. flat black paint for upholstery). This essentially means that I will be limited to insulating only hidden areas of the car (firewall, transmission tunnel, rear floor, rear quarter panel walls and perhaps the door skins).
A secondary issue is the reduction of interior heat (it was 102 degrees F the day that I was doing the noise tests which is one of the reasons for only one reading.) I don't know whether a single product can be equally good for both noise and heat reduction or whether it is a a compromise to obtain both.
Any suggestions on manufacturers of sound attenuation material that I could contact for this application.
Regrds,
Chuck
