Old 08-31-2004, 06:24 PM
mylesdw mylesdw is offline
Cobra Make, Engine: Ram 427 SC CSX6042. Chev 355. Quad Weber DCNFs
Send a message via ICQ to mylesdw
As far as brake balance goes, you can just fit an adjustable pressure limiting valve in the front brake circuit. When I built mine the factory suggested this and it works a treat. They explained that the set up of the chassis means there is very much less weight transfer under braking than say a saloon car so you don't need nearly so much brake bias transfer from back to front.
Myles D-W
