Old 09-02-2004, 07:55 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Okay, as I remember this from ages ago.
One tube is a vent that pre-dates the Charcoal Canister found on many 1970 plus cars. It vents to the outside ( I think ) and may have a check valve connected to the end via a rubber hose.
The other tube is a must. It goes between the filler neck and the tank an vents the air displacement as fuel is entering the tank. This MUST be installed or the fuel caughs back on the filler hose and all over the ground.
Provided you did this as a tank-out-of-body, you should have the seal plate with a rubber gasket or O-ring. The O-ring should be coated with light grease or vasiline. ( Ron will tell you I can not spell ). There should be two studs, bolts or electrical connection on the plate. One goes to ground and the other goes to the cockpit harness. There should be two tubes on the plate as well. ( Lord, please help me remember from 30 years ago ). One tube, the one that is bent to the side and goes all the way to the bottom of the tank with a screen on it, is the fuel to engine supply. The other, a short tube that just pops throught he bottom of the plate, is the filler tube vent. As I remember, there is either a rubber hose or steel line that runs from the last tube to the bent nipple at the filler neck.
What a mess. If you still have the tank out, put about a mason jar of gas in it and slush it around and pour it out. Examine the gas for debrie. Once the tank is clean on the inside, grease the gasket or seal and install the plate checking the float as you lower the assembly in the tank. Force the ring on the bung to lock the plate. DO NOT USE A STEEL HAMMER!!! Use a brass punch and hammer to gently force the ring on.
If you are replacing straps, try to get SS.
Hope this helps. Ron is a good person, I only hope I answered your question.
