Old 09-03-2004, 05:26 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
The best diif fluid is probably the synthetic stuff. I use Mobil 1 gear lube, something like 75w-90. Redline makes a synthetic gear lube as with some other companies. Even though it is for use in limited slip diff's, I was starting to get some clunking, so I had to add some of the limited diff additive as well.
You fill it up to the level of the fill plug, half way up the diff housing.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
