Old 09-04-2004, 04:21 PM
ridelikehell ridelikehell is offline
Cobra Make, Engine: BRM #20, Ford 302, Holley 600dp
Send a message via ICQ to ridelikehell
Default Update to the leaky rear main problem...PICS!
For those who were following this and helping me before I apologize for the repeated topic, but I thought that starting a new thread may yeild more replys...For those who haven't here's a breif overview...I suspected my rear main seal of being leaky so I ripped everything apart...There was quite a bit of oil on my driveway after idling there for about 15 seconds (about a 4 inch puddle)...
Now that I have everything apart and I have taken a look; here is my conclusion...(or my problem I should say)...Judging by the amount of oil that was on my driveway I suspected a very bad seal...However, the seal in fact looks fine; it's a little oily at the bottom but not TOO bad...Also, with a leak that bad I expected to see oil all over the flywheel, clutch and pressure plate...but there is little to none, maybe a touch on the flywheel but that's it...With this in mind I'm lead to believe that the leak is an oil pan gasket leak, and not a main seal...BUT there is still a bit of oil inside of the bell housing?
I've made a cardomain site of some pictures I took of the bell housing, main seal, etc. etc. so I was hoping someone with a little more knowledge on this could take a look and give me their opinions on the issue...Otherwise I think I'll just go ahead and replace both the main seal and the oil pan.
The link is http://www.cardomain.com/id/leakyseal
Thanks for your time!
--Dave.
