Old 09-05-2004, 04:30 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Smile
Dave,
Give me a ring if you have any more problems. I do see a potential problem with your set up...it will not fit under the turkey pan! We had to make a special fitting to work with the turkey pan.
We do not allow teflon tape in the shop for the very reason Roscoe states. We use loctite (low strength stuff on the plumbing) and ALL of our leaking problems went away. I even use it on the plumbing at home. NO LEAKS!
Let me know if there is anything we can do for you.
If you are messing with your carb anyway...there is a new carb out that is REALLY cool. Jorgen is using it and it really makes the car run nice. You will have to ask Thomas for the specifics, though as I can never remember the numbers.
David
