Old 09-06-2004, 06:58 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
You have to check by grind number, not the part number.
I'm running a crane solid roller as well, part # 34SR00006, grind number SR-256/374-2S1-10 ( SR stands for special roller) Crane doesn't list my cam as it is a special order item.
lift I-.658", E-.658" Lash .020 on both, so effective lift is .638"
Dur @ .050 I-256, E-264
My cam has a little less duration, but about a .050" bigger lift. I definitely would not get any more radical than this for a street driven car. It needs to be at about 3000 rpm's to run perfectly smooth at cruising
Ernie, here's the link to your specs.
http://www.cranecams.com/?show=brows...61&lvl=2&prt=5
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
