Old 09-07-2004, 01:50 AM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Ernie, A word on your compression ratio....Cylinder cranking pressure does not equal compression ratio. My cam last year had 285 lbs cranking pressure and 10.6 compression. My cam this year has 185 lbs cranking pressure with the same 10.6 compression. I didn't change anything but the cam. To get your compression ratio you need to know bore, stroke, head gasket compressed thickness, deck height, piston dish or pop-up and head cc's.
http://www.campbellenterprises.com/R...o%20calculator
Here's a link to figure CR when you know the above numbers.
Jack
XSSIVE .....
