Old 09-08-2004, 04:59 PM
Nor Cal Al Nor Cal Al is offline
Cobra Make, Engine: Cobra-less
Anthems Wilwood package is really neat and works well. If you have the short clutch arm and choose the outer hole on their mount, it is a perfect setup(a pull not a push). Their bracket set is machined aluminum and bolts through the motor mount. Caution, make sure you get all the necessary fittings. I was missing the adapter fitting for the hose to slave connection and could not find locally (wrong type flare). I had a custom hose made.
P.S. the slave is available from Summit.
Cobras Gone But Not Forgotten
