Old 09-09-2004, 04:43 PM
Excaliber Ernie can you post a picture of the push rod and the bottom of the rocker. That shaft is broken in the middle of a mount and snapped side to side on top to bottom. Too much lash started the problem. 600 lb springs is also not helping. That push rod would bend and twist before it would break that shaft in half. Is that the mount in the picture? Do you know what push rods you have in the motor? Chromemoly? Steel? Befor Mike gets $20.00 I want to see the rest. What's the address Mike??? Rick Lake Ps how big is the hole that pushrod is passing through? Intake manifold modified? Thanks Ernie.
