  #25 (permalink)
Old 09-10-2004, 12:11 PM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
Hey, Lee. All you have to do is give Marvin a call. He'll whip out his cutting torch and have you ready to go in no time flat. I agree with the previous posters that the AOD tranny is the way to go. You built your car as a cruiser, not a dragster so you probably want around 2400 RPM at 70 mph. The AOD will keep the noise level manageable as well as provide a smooth responsive ride. You may have to have a new tranny cross member fabricated and a new drive shaft made up. That C-6 seemed awfully long sitting under your car.
I run a 3.50 rear gear with a toploader and turn 2850 RPM at 70. My winter project is to swap out the carrier for a 3.00/1 carrier that should provide 70 mph at 2450 RPM.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
