Old 09-11-2004, 08:00 PM
Keithc8 Keithc8 is offline
Default New 427C.I. SB Special
We have once again been working on our vendors to bring you a package that is second to noe on performance and price. When you consider the parts and the power this package offers it is hard to beat.
Dart iron block, Eagle 4340 steel crank and H-beam rods, JE/SRP pistons for 10.5 to 1 compression, Custom hydraulic roller camshaft, Ford Racing hydraulic roller lifters and double roller timing set, Canton T-style oil pan and pick-up tube, front cover, SFI harmonic damper, pointer, Edelbrock water pump, AFR 205 heads, Comp Cams pushrods, Scorpion roller rockers, Edelbrock Victor Jr intake, Keith Craft Racing Logo valve covers or choice, MSD distributor and Ford Racing wires, DaVinci 750, Ram steel flywheel, March pullys, power master alternator and brackets with belt. Engine is professionaly built with build sheet provided, dyno tested and tuned. This engine will produce 550ft/lbs torque and 550HP and is available with head and camshaft up-grades to bring power to 600HP.
The total price for this special package is 12995.00 plus feight. Please mention the special on Club Cobra for this great price. Thanks, Keith Craft
Keith C
