Old 09-12-2004, 11:00 PM
Ant Ant is offline
Default Oil system
2KWIK4U.
The oil cooler can be plumbed either way.
Regarding the remote block that goes on where the original oil filter housing went, you need to look at where the line fittings come off your new adapter, make sure the return line after it has gone through your remote filter and oil cooler, this must go into the main oil gallery, so the general idea is return clean oil at the right temperature (oil thermostat required) into the main oil gallery!
Hope you can understand that!
A J. Newton
The 1960's rocked!
