Old 09-13-2004, 07:28 AM
jayem jayem is offline
Cobra Make, Engine: 65 la exotics 351W supercharged
I have run a blow-thru set-up on both a 289 and 351W. I use a used procharger I bought for 1200 dollars, seems bullet proof.
Comp cams makes several great blower cams, mine is a 512/520 lift. I ran a 9 to1 compression bone stock 289 with 7 lbs of boost and got 300HP & 340 TQ at the rear wheels. The 351W I had built with forged pistons & ARP bolts and run at 10 lbs of boost.
It Dynoed at 330 HP & 380 TQ at the rear wheels needing Carb & Timing adjustments. After Dyno Tuning I should gain 40 or 50 more on both the HP & TQ. If your interested I still have the custom built 625 CFM Holley Blow thru Carb that I will give you a good deal on ( I had a 750 CFM built for the 351W). Jay
