Old 10-10-2004, 05:57 AM
Joea Joe check all your power feeds for tight connections. I would start with the battery cables first. Sounds like a loose connection. Do you have a master battery kill switch? Once the car is running it uses the Alt to keep running and recharge the battery at the same time. Do a basic check before you start going crazy down the wrong road. The igntion switch can be tested with a test light for what Bob is talking about. May sure the Alt output wire to the battery side of the starter soleniod is clean and tight. If you don't find the problem come back with what you have found. Rick Lake
