Old 10-10-2004, 10:19 AM
My427stang My427stang is offline
Cobra Make, Engine: ERA, 496 Tunnel Wedge
Send a message via AIM to My427stang
I run 11.5:1 in my heavier Mustang on 89 Octane. The trick is polish everything for no hotspots (valve reliefs, edges of valve, chamber, etc, and in your case I'd probably have the chambers opened slightly, unshoruding the valves for more airflow and even bore matching while cheating a few cc's out.
With a timing curve of a 26 degrees in no sooner that 2700 or so, and an initial of 12-14, you should be fine on 91 pump gas in the lighter car
The last thing is, make sure you are running a cam with some overlap, if you go with a mild cam, it will ping
1994 ERA Cobra, 452 side oiler, C5AE-F, Tunnel Wedge
70 Mustang Fastback, EFI 489 FE TKO-600, too much to list
71 F-100 4x4 EFI 461 FE restomod
Bullock's Power Service, LLC
Concours and performance engines by appointment only
https://www.facebook.com/BullocksPowerService
