Noting your location and that you have an ERA. The fuse block location of an ERA leaves it open to the outdoor elements (not intended to be a criticism but rather an observation). I would do exactly as Bob suggested and check continuity at the fuses. The damp air over time, has in the past, caused a mild corrosion issue for the fuse controling the tail lights for me. Just clean the fuse ends with a little 600 wet or dry sandpaper.
Rick
Rick
