Old 10-11-2004, 04:06 PM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Thought I had it. It sounded so good.I didn't see any gas drueling in.It was running good enough that my wife came along for the ride. got about three miles from home ten minutes tops and it started runnung ruff.A block later and I turned it around .It was getting worse,Idle seemed ok but off idle was terrible..I'got it home you could see the fume cloud in front carb ,plates look wet.I'll bet the plugs are fouled again.I checked the float levels again, as right as could be.
When I removed the original pv's they had two gaskets .What was that about?
Mike H
