Old 10-11-2004, 05:44 PM
dbaker08723 dbaker08723 is offline
Cobra Make, Engine: Lone Star 350/385 hp Chev "Fast Burn"
Default brackets
For what its worth....
My side pipes bracket was welded to the pipe and bolted rigidly to the frame. The drivers side pipe cracked (right at the weld)
I called the manufacturer (Lone Star) and they said to put about 3/8" or more of sheet rubber between the frame and bracket...
I had the pipe repaired, put in the rubber and so far so good.
I took the pipe to a place that manufactures Tuna towers for fishing boats... they are really familiar with this kind of work..
good luck....
