Old 10-12-2004, 03:44 PM
SVMCOBRA SVMCOBRA is offline
Outlaw, Pasadena is right outside off Houston. I have not had any problems with brake fluid boiling out. After looking at your pic's I wonder if the bracket that is bolted to the top of the foot box that supports you column might be the problem. If I remember right that bracket is bolted to the column, could the bolts be expanding when they get hot and rubbing the steering shaft.
