Thread: Bad Ground???
Old 10-15-2004, 06:04 AM
Northwood Cobra Northwood Cobra is offline
Cobra Make, Engine: B&B
That's exactly whats happening. I'm thinking I probably screwed up in the ground area, with the battery at the back of the car I only used a standard battery ground cable but I attached it thru a self tapping screw that's holding part of the body on. So there is even a piece of fiberglass between the end of the cable and the frame, so really, the only part of the ground wire that's touching the frame is the self tapping screw. The rest of the starting system is #4 wire with heavy terminal ends. I'll redo that and see if that corrects my problem.
Thanks alot, Terry
