The web site was a major help .The picture of 38 series showed my advance system.YL The older stuff again.Do you think the factory curve kit would actually create the desired curve or do you think I'd have to test it on a distributer machine?Or just let the pros do it?
Also with the spark plug wires in the cap as before The hold down bolt is incumbered by the tach drive at 12° bftdc Any less advance and the bolt is burried. The drive gear has 15 teeth that works to 48° per tooth to resolve this perdicament, I think I'd have to relocate the wires in cap( 8 evenly spaced wires should move 90°) and try another placement,with the limited movement the Tach drive affords , I haven't thought of any other allternative.
Mike H
