Old 10-19-2004, 11:21 AM
scottj scottj is offline
Cobra Make, Engine: Everett-Morrison, 434 cid
Originally posted by brainsboy
You should not use H-series bearings unless you have too.
"have to" means if you have a large fillet crank you have to run the H-series. If you have a stock, small fillet crank use the P-series.
Also, the P-series has a little more lead than the H and is a little more forgiving.
The difference in eccentricity doesn't factor in to the decision in the least for a mild street engine.
Scott
