Old 10-19-2004, 07:46 PM
maxrpm maxrpm is offline
Cobra Make, Engine: Shell Valley- smallblock grenade w/ the pin pulled
I'd put my money on the firing order. Although both 351W and 302 cams are interchangable their firing order are not. To confuse the issue even more, some computerized 302s (Mercs&Crown Vics) actually used the 351W order. Pretty common mistake. The car will actually run but will not take any rpm. Once, I had a late night thrash setting my car for a day at the dragstrip. Decided to change rear gears,axles, intake, distributor, cam the night before racing(why do we do that?). Left dist installation & firing order to one of my buddies. The car actually ran ok the next morning. Drove it thru the pits not noticing. I did a burnout, staged and made it to about 3500rpm in 1st gear. Went back to the pits and found the mistake. Reset your wires and rev that sumbich!
"If you're not racin' it, you're wastin' it!"-Me
