Old 10-19-2004, 08:05 PM
maxrpm maxrpm is offline
Cobra Make, Engine: Shell Valley- smallblock grenade w/ the pin pulled
Originally posted by Jetlaag
Also, after the pushrods are tightened and you turn the motor over a few rotations by hand, are the pushrods on the closed valves supposed to able to be turned with you fingers or not??
Sounds like your valve adjustments are good to me. Or at least close enough to run without backfiring.
"If you're not racin' it, you're wastin' it!"-Me
