Old 10-20-2004, 04:13 AM
DAVID GAGNARD's Avatar
Jack;
You need to use the firing order for the cam installed regardless of what the firing order was before,as said before,some cams use the "old" 302 firing order and some use the 351 firing order.........check your cam card and use that firing order and I think your problem will be solved.........
David
DAVID GAGNARD
