Old 10-22-2004, 12:25 PM
BPWilliams's Avatar
BPWilliams BPWilliams is offline
Cobra Make, Engine: none
Default Coldddd
Remember a cold enging generates more HP, but how is your oil pressure? Mobil 15-50 gets pretty thick at those temps. I have a BB 429SCJ that runs a 180 thermostat and I need to block off my oil cooler duct because the oil gets too cold, even in AZ. I also run Mobil 15-50 for track events and on the street I see a 5 to 15 psi increase in oil pressure at cruzing speeds because of oil temp. You might want to change oil to a more friendly version for cold weather unless you plan on tearing up the track on the weekends.....
Keep it above 100.........
Brian
There is No Replacement for Displacement.
U.S.A. All the Way!
