Thread: Jag Irs
Old 10-24-2004, 08:04 AM
Bruce Edwards's Avatar
Bruce Edwards Bruce Edwards is offline
Cobra Make, Engine: Hunter with a 4.6 supercharged
JB,
As I recall Street Best frames are set up for the late model Mustang Fox body link with the 8.8. What kind of engine and HP are you planning? If you are staying with a mostly stock 302 don't worry about it. If you are going to the 400+ range you will need to install a stronger rear end in the car. You can cut down a 9 to fit and weld on all of the attachment points so it will work in place of the 8.8.
Of course that is still a solid axle.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
