  #40 (permalink)
Old 10-24-2004, 07:57 PM
Ant Ant is offline
Default Best small block for a cobra
Why dont more people look at the 331 smallblock with alloy heads and waterpump, several reasons:
PROS:
Run more compression due to overlap etc with higher rev camshaft, but still on pump gas.
Get 450 - 485bhp - which is similar to the bigger strokers.
Better handling for road racing, and driveability on the street.
Sound great like a GT40.
Easier on bottom ends.
Dont need a five speed heavy road style transmission with a semi-useless first gear, and an overdrive, just rev it out to 7000 in top (3.27 ratio on 26.5 tires), and have a usuable four speed like:2.60,1.72, 1.28,1.00 Jerico, weight 65Ibs or an alloy Toploader.
Less drivetrain issues
CONS:
If running over 7000rpm a lot rocker gear becomes a problem.
Less grunt down low for drag racing or street.
Expense for a decent block (Dart etc) and Rocker/Valve gear.
Still like the idea of a 393 for the grunt, but I reckon hearing the small blocks at the race track does it for me!
A J. Newton
The 1960's rocked!
