Thread: Hot Engine
Old 10-27-2004, 04:26 AM
750hp's Avatar
750hp 750hp is offline
Suggestions? Yeah - move somewhere cooler !!!! VDO gauges are generally very accurate. Assuming those city temps are right, you definitely need to make some changes. Oil and water temps at or above 120 cannot be sustained. In fact, many motors would have pretty ordinary head gaskets after temps like that, but the windsor motors can seem to cope with overheating better than others (LS1s for example - that'll get them talking...)
An oil cooler is obviously going to make a worthwhile difference to oil temps, but I'm still concerned about the difference between city / highway driving. You don't have any engine bay photos in your gallery, so I'm not sure if you have shrouding around the radiator. Are you sure the water pump is the correct rotation for your year motor, because standard and reverse rotation pumps can physically bolt onto either timing cover. Fans verified to be switching on at correct temps?
So many variables, but one thing is for sure - 120+ is too high !!!
Craig
