Thread: Alumium Head
Old 10-27-2004, 08:50 PM
mustangmendez mustangmendez is offline
Cobra Make, Engine: Custom Built Classic Motor Carriage T 5 Z tranny still in the making ..
Default Alumium Head
ck out whats on sale on ebay Edelbrock RPM SBF 2.02 Head #602519
Item # 7930034062
Bid and win
Reg price 699.00
buy the unpolished to match and save even more
sorry only have one .....
Bolt-on power, right out of the box.
Cylinder Head, Aluminum, Polished, 60cc, Ford, Small Block, Windsor, Each
All Edelbrock aluminum cylinder heads feature threaded inserts in the rocker studs and exhaust manifold bolt holes for superior strength and durability, plus hardened seats, bronze valve guides, and fully machined valve cover rails for a more consistent gasket seal. They offer improved power throughout the rpm range for greater throttle response and top-end horsepower. The intake and exhaust runners are CNC-machine profiled for superior flow and performance. Performer RPM heads are fully assembled with stainless steel intake and exhaust valves with undercut stems, 2-ring positive oil control seals, rocker studs, hardened steel guideplates, valve springs, retainers, and keepers.
Vendor Edelbrock
Product Line Edelbrock Performer/Performer RPM Street Cylinder Heads
Cylinder Head Style Assembled
Cylinder Head Material Aluminum
Cylinder Head Finish Polished
Combustion Chamber Volume (cc) 60
CNC Machined Combustion Chamber No
Intake Runner Volume (cc) 170
Exhaust Runner Volume (cc) 60
CNC Machined Intake Runner No
CNC Machined Exhaust Runner No
Combustion Chamber Style (Not Specified)
Intake Port Shape (Not Specified)
Intake Port Location Standard
Exhaust Port Shape Rectangular
Exhaust Port Location Standard
Spark Plug Style (Not Specified)
Intake Valves Included Yes
Intake Valve Diameter (in) 2.020
Intake Valve Diameter (mm) (Not Specified)
Exhaust Valves Included Yes
Exhaust Valve Diameter (in) 1.600
Exhaust Valve Diameter (mm) (Not Specified)
Valve Springs Included Yes
Outside Diameter Of Outer Spring (in) 1.450
Damper Spring Included No
Number Of Springs Per Valve Single
Retainers Included Yes
Retainer Material Steel
Locks Included Yes
Lock Style 7 degree
Valve Stem Seals Included Yes
Valve Stem Seal Style PC seal
Rocker Arm Studs Included Yes
Rocker Arm Nut Thread Size 3/8-24 in.
Rocker Arms Included No
Rocker Arm Nuts Included No
Guideplates Included Yes
Guideplate Pushrod Size 5/16 in.
Valve Cover Mounting Style (Not Specified)
Accessory Bolt Holes Drilled Yes
Intake Valve Angle (Not Specified)
Exhaust Valve Angle (Not Specified)
Valve Guides Included Yes
Valve Guide Material Manganese bronze
Valve Seats Machined Yes
Valve Seat Machine Style 3-angle
Valve Seat Material Ductile iron
Steam Holes Drilled No
Oiling Style Through pushrod
Machined For O Ring No
Heat Crossover No
Quantity Sold individually.
Notes (Not Specified)
You can by a non polished head with the same specs for 559.50
So you can have a set of nice hiflow heads for under $1000.00
Tony Mendez
King Cobra
ALL IT TAKES IS TIME AND MONEY !!!
God Bless us All
