Old 10-28-2004, 06:27 AM
Sizzler Sizzler is offline
Originally posted by Double Venom
Sizzler-Do you really think the Gen. II dual intake manifold with two throttle bodies is better? I thought the whole point of the new intake was to not only make it simpler but this is what they, the "Toy Factory" came up with to gain most of the additional 50 HP. That and a new cam. Not a debate! Just really curious on this one.
Yes.
Though the red one weighs at least twice what the (let's call it) white one does. It is probably a moot point; the thrill and accomplishment will be in getting the engine, as it is, installed and running in another vehicle. BUT, if you eventually want the maximum performance, the red intake flows better and will support higher HP levels. It also can be extrude-honed for even greater flow and capacity...I would be very very frightened to have the white one subjected to any kind of pressure, be it forced induction, or extruded putty. A runner would burst for sure they're so minimally-walled. Think of the white intake as Ford's 5.0 cammer. It's nice as it is, but if you want to go bigger, stronger, harder, well, don't. It just won't take it.
You do realize that, in a Cobra, the Gen III engine will sound like the Gen II? The Gen III got a crossover exhaust that 'corrected' the exhaust sound.
Good luck.
