Old 10-29-2004, 11:49 AM
Curt C.'s Avatar
Curt C. Curt C. is offline
Cobra Make, Engine: Classic Roadster; 351W
Default Tilton Hydraulic T/O bearing
I have a used Tilton Hydraulic release bearing, part number 61-600 and the release bearing retainer for a Tremec 5 speed, part number 61-621. I ran this set-up with a 351W, Centerforce dual friction clutch and a Tremec 3550. The unit is in perfect operating order. The stainless steel braided line that runs from the MC to the T/O has a slight kink in it, but it did not affect operation. You can replace this line with steel braided brake line for like $20 if you are not comfortable. Parts have been throughly cleaned in rubbing alcohol and prescribed in the directions. Directions come with the parts. These parts may work with 302's and 289 clutches and other Tremec trannies, but please contact tilton to make sure. These parts retail at Summit for $279.99 and $129.99. I would like to get $250 for the lot. I also have the Wilwood clutch pedal, part number 340-1289 which retails for $57.99 from Summit. All you need is the Wilwood 3/4 master cyliner, 260-1304, for 45.95 to make the whole thing work. Pedal costs $30.00. Email me for pics if interested c.croshaw@att.net
