Thread: Clutch "issues"
Old 10-31-2004, 07:30 PM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
If you adjust all the free travel out of the pedal and master cylinder you will more that likely move the master cylinder piston off its natural stop and cover up the tiny hole that lets the actual master cylinder rerfill from the resivior.Make sure that the piston is resting at the end of the master cylinder against the snap ring and not against the pedal.Also let gravity and time help .Let the air settle out of the fliud and don't get it airated again. Keep the resivoir full.Air will try on, it's own ,to work it's way to the top.Brake fliud it viscus and the bubbles will linger a while.
Mike H
