Old 11-01-2004, 04:09 AM
Fox's Avatar
Fox Fox is offline
Cobra Make, Engine: 302 done, CSX289 comp body, leaf spring chassis to original specs...
On the left: The red cable is + from the battery...The black, hooded red is going to the + starter solinoid terminal.
The cable colors are confusing but that is what came with the FRPP starter and how it is labled in the instructions.
On the right: The 12 ga black goes to the outer "blade terminal" of the solinoid. Is that correct? GR, are you saying that the large right post is -/ground?
Since this is mounted on wood and not the engine compartment, I grounded it in the upper right corner ( red 12. ga).
In my Summit ignition switch/starter button instructions it sends a wire to the battery, one to the ignition (the MSD, right?) and the last to the starter.
Should that "starter wire" (of the switch) go to the S terminal of the relay?
Thank you very much Ernie...This sh!t can give me a headache, but you example was very...Slick.
I appreciate any help...in physics I could play golf with a bb gun...but right hand rule/black box electrical always had me lost.
-John
So you been broken and you been hurt, Show me somebody who ain't
Yeah I know I ain't nobody's bargain, But hell a little touchup, and some paint...
