Old 11-01-2004, 09:27 AM
Fox's Avatar
Fox Fox is offline
Cobra Make, Engine: 302 done, CSX289 comp body, leaf spring chassis to original specs...
Thanks for the grounding point. As I said, I did make a effort to ground the relay, but not using a terminal, I grounded the mount.
I sense that it is still not hooked up right at the main terminals. There are two wires going to the solonoid, on either side of the relay??? In the picture it is the red hooded black cable to the + post and on the right side it is the black 12 ga. going to the 'blade terminal'. I will review the directions from Ford and will likely post for a clarification tonight.
I am sure you are all just stirring with anticipation...but I thank you for your patience and helping me clear this up.
-John
So you been broken and you been hurt, Show me somebody who ain't
Yeah I know I ain't nobody's bargain, But hell a little touchup, and some paint...
