Fox, I am using the same setup on my Shell Valley with a 351W.
The big left post is for the battery and power to your fuse box. The big right post will have have two wires, 1 big cable to the starter and 1 smaller gauge to the solenoid. The small post on the left goes to the ignition switch and you have to ground the solenoid bracket. I do not use the small right post because I am using an MSD ignition system
Ray Hedden
