Old 11-02-2004, 05:21 AM
sirelesar sirelesar is offline
Cobra Make, Engine: B&BEFI 302 w/ AFR Heads 3.73 Rear, Coil-Overs
I respect those that are concerned about spine compression. After much deliberation, I placed mine so that the straps run between the lip of the body above the seat and the tub of the cab behind the seats. They then attach to the steel support that runs along the width of the body that attach the trunk lid. That gives a wide footprint for the straps to comfortably go over the shoulders. Note: This steel bar is supported by the fiberglass body, but the entire rear end would have to shear away. A better method would be to weld a steel beam across your roll bar below the body, and go to the frame on the passenger side for a wide distribution. I did not do that before permanently mounting my body to the frame. In retrospect I probably would have.
Hope this helps. Remember, you only get one shot at it.
Darren
