Old 11-04-2004, 02:02 PM
PJS50's Avatar
PJS50 PJS50 is offline
Cobra Make, Engine: SPF#131 520 cubes; 650 HP
Is that you Don?
Good to see you here...
I have put together all of the specs I could rergarding my Cobra on your "spec sheet" and I will be emailing it to you soon...
I look forward to strapping on the Demon (Mighty 850cfm) this winter...
I plan on re-curving my distributor just before I do the carb.
I have a 460 Ford Crate motor. A local told me to go up to 36 degrees total advance at about 3000-3500RPM(?) with initial timing somewhere around 15-16 degrees. My cam specs are 244 intake/254 exhaust at .050". I am running about 10.5:1 compression according to the specs that came with the car...
I know this is very limited info, but does that advance curve sound about right? Is this too early to be at full advance?
Pat
Shooter...Looter...Not Neutered.
