Thread: Ignore (EOM)
  #285 (permalink)
Old 11-05-2004, 08:02 AM
rdorman's Avatar
rdorman rdorman is offline
Renegade Nuns on Wheels
Tru, I would dump the Torker. Not good downstairs. The 4V strip dominator is better, but very hard to find. The blue thunder intake makes almost as much as the strip dominator but has a much, much better torque curve. I have seen back to back dyno tests on all of these. Plus, you can still buy the blue thunder intake.
Now if you can go a little more, then try the crane f246 (246/256 and .570/.590) and a parker funnelweb. No real head work aside from parkers port stuffers. 480HP at 600 (still pulling 477 at 6500) and 451ft-lbs at 4750. The parker alone is worth 36HP and 28 ftlbs over the strip dominator. AND a much broader torque curve, a rare thing indeed. Expensive though and a lot of work to install. This was a 12:1 motor, so obviously actual results with a street compression will be less.
Rick
OhioCobraClub.com
LondonCobraShow.com
