Thread: Ignore (EOM)
  #296 (permalink)
Old 11-05-2004, 11:27 AM
rdorman's Avatar
rdorman rdorman is offline
Renegade Nuns on Wheels
Default Re: Rocks
That may be, but I still do not have any cheese.
Ans. You may have some of mine
And, I have a large quantity of rocks.
Ans. Large rocks or large in quantity.
Since you started it, how do I get 15 pages from the 20 I see.
Ans. larger monitor with higher screen resolution settings.
BTW, I run the torquer for the 6000 to 8000 RPM range. The 4V heads were never designed to run below 3000 RPM.
Ans. That cam is done at 6500, so why 6000 to 8000? Blue Thunder had nearly the same top end as the Strip Dominator and better than the Torker, while still having a better bottom end. For single plain, nothing beats a funnel web!
So you think you are hitting 346 at the wheels? That is good to here.
And. 346 was corrected torque (if they didn't already correct it). I would like to get to 340 uncorrected with the current setup.
Do you realize you hadn't started the CAM work at the beginning of this thread an now you are done?
Ans. No!
Viagra can't compete with this thread.
Ans. I hadn't thought of Viagra, but a number of seditives and anti-depresents came to mind
Rick
OhioCobraClub.com
LondonCobraShow.com
