Old 11-05-2004, 10:27 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Okay, you can, if you wish, test your wiring to the Ford regulator by placing a 12 V, 85 mA bulb in series with the I terminal wire.
You sort of have a difference of potentials that will make the lamp glow if the alternator output is not enough to change the battery.
I have a schematic of a 65 or 66 T'Bird in the gallery that will show you how to connect things up.
Hope this helps.
If you put the lamp in series with the I terminal, you will not fry the regulator ( provided it is wired correctly in the first place ).
