Old 11-06-2004, 07:02 PM
FFR428's Avatar
FFR428 FFR428 is online now
Cobra Make, Engine: HM-2027 / 427 SO
Forgot to add yes the 427 will bolt right in with the FFR mounts. Now there are two styles of FE motor blocks. The early 2 bolt motor mount and the 65 and later 4 bolt motor mounts. My 406 has the early 2 bolt block and had to partially grind to mount to fit around the hump cast into the block. It's by the drain petcock on the early blocks. I can send you pics if your using a early 427. G.
