Old 11-07-2004, 08:25 AM
dlampe's Avatar
dlampe dlampe is offline
Default Great 351c street motor
This is a 351 Cleveland with only 500 miles on a complete rebuild.
The short block is almost stock with the exception of dome top TRW pistons. All the bearings where replaced for the rebuild. It is a 4V head motor (these are the good ones!) The heads are the open chamber Cobra Jet heads. Compression is aound 10.5 to 1. It runs great on pump gas. It has new Comp springs and retainers as well as new valves. The cam is a new old stock SVO cam with .536 lift and around 234 dur at .050. It has a new SVO double roller timing chain. The intake is an edelbrock Performer. The valve covers have been cosmetically modified to match the black krinkle paint on the air cleaner. It needs an oil pump and carb, that is it! I have a carb that could be a seperate deal and I needed the oil pump for my race motor. This is a steal for $1500. I will consider a Toploader on trade. You can see a picure in my gallary. It is on the engine stand.
Contact me at 618 322 6046 or post!
Dean
