Old 11-07-2004, 09:51 AM
Fox's Avatar
Fox Fox is offline
Cobra Make, Engine: 302 done, CSX289 comp body, leaf spring chassis to original specs...
Well...
Using a heavy duty drill, I now get just over 25 psi but still no noticibe flow through the holes for the push rods.
I looked in the drills owners manual and it gives a no-load max at 2700 rpm's. So even with the load at worst I should be getting 1000 or so, meaning the equilivent of 2000+ crank rpm's.
Just to be clear, this is a 302 with a HV mellings pump in a road race Canton pan with a windage tray. The cylinder heads are aluminum GT-40X. It is on a run stand and not in the car.
Before I drain the block, and remove the pan to check the pick-up and pump, is there anyting else I should be aware of or try? Is there possibly a gasket covering a galley like what can happen with the water galley and a cylinder head gasket if it is put on backwards?
I appreciate the help and insight.
-John
So you been broken and you been hurt, Show me somebody who ain't
Yeah I know I ain't nobody's bargain, But hell a little touchup, and some paint...
