Thread: Engines.
Old 11-08-2004, 01:01 AM
ledge ledge is offline
Cobra Make, Engine: 1st Harrison with Gen 3 , 6 speed ,Godzilla diff & brakes
Cool
Jase .
I was origonaly going to use a Ford motor but ended up on the dark side for more reasons than it is easier to get through rego like for example, More power , Lighter , Looks better need i go on .
At the end of the day you not building a Ford car anyway you will be building a Jase and im building a Ledge and all the other guys here are building there own car also ,Its just we chose to use a fibre glass body that resembles a 1960,s race car .
So the best bet is to put in what you want in it .
By the way you should be able to use older motors i know here in SA you can use any motor you want but if it is older than i think 1995 it has to run on gas alone with no fuel tank in the car at all .Then it will pass current emmission laws .And all your motor needs to do is pass current emmision laws
Paul
