Old 11-08-2004, 10:21 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Default FE Cam Specs and selection
Its' almost winter and I am pulling my engine for some maintenance and upgrades.
Maintencane: Replace all bearings and timing chain and gear. Leak down check of rings and valves showed an insignificant wear.
Upgrade: Thinking about upgrading my cam to a .605 lift and 248 duration solid lifter Comp cam GRIND #294S. OR .640 lift and 260 duration solid lifter Comp cam GRIND #306S. I am also considering new dual valve springs and solid roller lifters.
Key to any upgrades is that they maintain streetability and be useable with a 10.6 : 1 compression ratio and dual plane manifold.
Anyone out there have any thoughts or recommendations.
FYI for the last two race seasons I have been running a .571 lift 236 duration solid lifter cam and absolutely loved it but I need a few more R's.
Clois
"Let's roll"
"Be part of Something Good
