Old 11-08-2004, 10:50 AM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Clois-
Right now I am running the Comp Cams 292H, which has .560 lift and 244/244 duration @.50. I am actually going to change it this winter to the cam you are currently running.
Although the 292H is very streetable, (idles great at 850-900 rpm- vacuum is very poor at idle though), I've found that the cam is no fun on the road unless it is revving over 3000 rpm. Because my use is limited to street driving/cruising, I want something more well mannered with better torque in the lower rpm, so out it comes.
But, if I were going to put the car on the track every now and then, I would be inclined to keep the cam because it does pull well in the upper rpms.
Replica is not a dirty word.
