Old 11-09-2004, 07:41 AM
MAXVELO MAXVELO is offline
Cobra Make, Engine: West Coast Cobra weber fuel injected 557 C.I.. 800H.P 760LBS. TQ. Magnum T56
Send a message via AIM to MAXVELO
Default DV, I GOT A COUPLE QUESTIONS....
Can I make the assumption that all I need to make this puppy run is a MAP sensor, MAF sensor, TP sensor, O2 sensor etc? The fuel pump I have is a SX performance setup w/filter so my pump isnt lacking any PSI power. what did you have to do to your harness (what did you delete and what did you use? Also do you know the differences between mine and yours? I have'nt had a chance to go to the dodge dealer for any info from thier manuals but I'd just like to know what Im in for. By the way why does the computer care what the battery temp is? I cant imagine that your harness is that much different than mine. The only difference I can see is you have two seperate throttle bodies and I have one. Do you have 2 seperate tps's or does it only read one? Also why 4 02 sensors? can they be wired to trigger off 1 or 2? Im just comparing it to the Accel DFI system requirements.
WHEN YOU HAVE MORE HORSEPOWER THAN YOU NEED ITS STILL NOT ENOUGH!!!!!!!
